Mistress -82 restoration
#31
After that some clear coat was applied to the transom, and the hull was moved to another hall to let the primer cure for a couple of months.
Finally I was able to get some photos or the entire hull and to see the hull lines without any stripes.
[ATTACH=CONFIG]517650[/ATTACH][ATTACH=CONFIG]517651[/ATTACH][ATTACH=CONFIG]517653[/ATTACH]
[ATTACH=CONFIG]517654[/ATTACH][ATTACH=CONFIG]517655[/ATTACH][ATTACH=CONFIG]517656[/ATTACH]
[ATTACH=CONFIG]517657[/ATTACH][ATTACH=CONFIG]517658[/ATTACH]
Now I think that's enough photos and updates for today.
#33
#34
1985, that's without windscreen but with a straight wind deflector, or am I wrong?
I'm getting to the power in a few posts, but don't get you hopes up on something fancy, I went for a "economical" solution instead of a high-power one.
#35
It has a aluminum fairing on it. Will post some pictures soon. Had a friend paint it that does bump work for a living and redoing some of his work. I gonna be married to this thing after all the bills add up but it's by choice I think. Built a pair of 598 dart blocks and imco scx drives on boxes. Brian41 is helping with rigging them and were raising the X. Hoping the old turd breaks 80.
#37
Thanks for the comment, I hope I can keep your interest up!
If I recall correctly it was about this time in the project that the guy doing the paint job put on a serious face and looked at me and said: "I hope you're not thinking about putting the deck hatches back in the shape they are in."
I didn't really understand what he meant. A bit dirty perhaps?
[ATTACH=CONFIG]517728[/ATTACH]
But cleaning them didn't help much..
[ATTACH=CONFIG]517729[/ATTACH]
If I try to polish them then? OK better but it only made all the scratches visible.
[ATTACH=CONFIG]517730[/ATTACH]
So it was time to get serious first wet-sanding with grit 800 - 1200 -2000 to get rid of the scratches and then rubbing and finally polish. So now at least the plexiglass looks OK,
[ATTACH=CONFIG]517731[/ATTACH]
#38
But the frames looked quite awful too so the only solution was was sanding, primer and paint
[ATTACH=CONFIG]517732[/ATTACH][ATTACH=CONFIG]517733[/ATTACH][ATTACH=CONFIG]517734[/ATTACH]
[ATTACH=CONFIG]517735[/ATTACH]
Or for the smaller parts sandblasting and paint.
[ATTACH=CONFIG]517736[/ATTACH][ATTACH=CONFIG]517737[/ATTACH][ATTACH=CONFIG]517738[/ATTACH]
And in the end I got the hatches back to the boat ready for installation.
[ATTACH=CONFIG]517739[/ATTACH]
#39
The plan was to rechrome the ventilators for the engines.
[ATTACH=CONFIG]517740[/ATTACH][ATTACH=CONFIG]517741[/ATTACH]
But when I heard the pricetag for that work, which was about 5 times higher than buying new ones I changed my mind.
So here I will lose a bit of the original look, but I think these vents used for Bertrams will be an acceptable alternative and fit nicely.
[ATTACH=CONFIG]517742[/ATTACH]
(Now I feel like I'm getting into rather small details...)
