7 1/2 inches is very deep in my opinion. If you are not wanting to go through the trouble of changing it I would probably recomend starting with trying a 3-blade mirage ( hopfully you can borrow one ) , It usually works a little better than a 4-blade bravo in a deep x-application. I ran a 3 blade mercury tempest ( mainly a bass boat prop ) on my older 24' Pantera ( TRS w deep X ) & it worked great for it. It had alot of rake giving it great bow lift & the slip was right around 8-9%. ( which I realize would probably be a little higher on a 28' vs a 24' ) I believe that Saber ran a few turbo props on the 28's & liked them.
I am REALLY curious what the factory would set the X at on a new single ???????? ( Parnell ??? can you find out ??? )
I would think that with prop technology coming along way since the late 80's - early 90's that it would be quite a bit higher say around 5 1/2 " ????????????? I may know someone a little courious.
