Quote:
Originally Posted by jdub
Oh you will be fine. Both the Corsa and the Excalibur I did had around 18" X. They ran nice with not much trim needed. I know the Saber hull is a bit different but should benefit the same.
My only concern with this deep X on my Saber is I'm so used to not having to trim much to get optimal speed... when it got rough in my other boats (excalibur/corsa) they still ran nice and flat without having to tuck the trim in because of the high X. Now I will have to work the trim more in the rough so I don't send the nose up. I'm also curious about how it will feel with the gas tank located behind the back seat instead of the belly of the boat.
THATS RIGHT deep drive makes the boats fly straight up as in my baja which was high until I put the shortie on. so the yellow is at 18 you way need to use 5 blades but with the its it might be perfect, this is going to be rough fall, I need to figure on transom work on your boat and paint that black looks like b paint
, I now its not and the sides like you said need to grow on a person, they llook like maybe adding silver somewhere make it blend better so paint and thats it. compared to the others I am looking at that need paint transom whole done #2 30 supthens and one thats been instorage for 12yrs or more but looks new for 17,000 twin 454s so I would run that until I killed motors. and the new hulls I am looking at a 28 07 or 08 hull joker a sutphen 277 2010, and way off left over sutphen 32 red my favor it color haha but a wicked high price for 07 or 06 its not finished so. its tough I was all set one 30 was stripped and we were going to trade plus cash, but yours needs the least work what yr is the trailer and I need to set a road trip to at lest look at it and then talk about hp and drive. what hull are you looking at. the joker is a real fast hull but less room in cockpit theres a used one to they daid they would sell minus motor drive its a 2000, I wished yours was a lil newer thats all. but the red design is growing on me haha. well got to run if anyone can get back on the questions on the last three threads I posted on thanks about height speeds, if a 500hp with raised x would run 72 I could see95 to 100. the joker will run 106 or 8 with 900 hp been done. I have not looked at superboats just to small.
