| OSO Sponsor |
| OSO Sponsor |
06-11-2006, 11:28 PM
Need info ,120 degree celcius on a 350 mag?
Hi everyone
I've got a scarab 29 2000 with 2x 350 mag 300hp
one is running always at 150 degree celcius and the other always near 110 to 120 degree, is it bad , and is it thethermosthat ?
i've heard the best temperature is 160 degree .
Thanks for your help
06-12-2006, 07:32 AM
Powerboat Freak,,Cold Beer, Hot Women
Re: Need info ,120 degree celcius on a 350 mag?
I hope you mean fahrenheit.
Mine runs about 105 to 110, but I don't have a thermostat in mine. Does your engine have closed cooling or not? things to check for would be:
1.Whens the last time you changed your raw water pumps?
2. Is there a way to swap the sensors in block to see if its a gauge or a bad sensor.
3. Do you have another way to check your water temps with an alternate temperature reading source?
Nine times out of ten I have seen a bad raw water pump impeller.
Do some simple checks and I think you will find where the problem is.
Good luck!
http://sdwpower.igniteinc.biz/index.asp
06-12-2006, 02:57 PM
It's not your water pump if it's running cold. You may have something stuck in the t-stat holding it open, or the gauge /sender isn't reading properly. Have somebody check it with an infrared heat gun.(most mechanics have one)
06-13-2006, 12:26 AM
Knot for you!
1989 Formula F 35-7
HEY! Y s'tient fret pase que tu roules pas assez vite! (bad french sentence guys, I'm just kidding him)
06-13-2006, 01:35 PM
Quote:
Thanks everyone , that's help me to start...
Jeff: It's your fault if i can heat my block , your too s....
hihihiihihi
06-17-2006, 12:06 PM
Knot for you!
1989 Formula F 35-7
your right!Compared to me right now, at least you are running!
06-19-2006, 01:16 PM
Jeff can't wait to fly at the beach with your family...
I saw a new thing in your driveway , is it a rollerrack for a formula ???
06-21-2006, 11:34 PM
Knot for you!
1989 Formula F 35-7
this is to lift the different boats from their trailer, Faster, and safer than floor jacks to lift these (sometimes) heavy hull...
| Thread Tools |
Search this Thread |
