Quote:
Originally Posted by Hot Boat
Thanks everyone for the compliments.
Unfortunately I blew the motor a few weeks ago. I had a head gasket leak and melted the #6 piston. I will be building a 700 hp motor for her the winter. I want to see 86+
Hay Strippoker did you have to cut the fire wall on yours to fit the blower pulley. I want yo use a 6-71 or 8-71 blower but I don't think I have the clearance to the fire wall. I know I will have to cut the top of the deck where the hatch sits. I am not sure that when I replaced the fire wall that it is in the same place. It might be a 1/2" closer to the motor. What do you think??
Your boat is looking great!! You have done a hell of a lot of work..I had to cut it.The lip right by the upper blower pulley prob about 2 inches,The top part is part of the top deck so that didn't move when you moved the firewall/bulk head. The bulk head below that I had to cut it out for the blower belt.The bottom pulley clears ok.It just 3/4 plywood with black carpet on it,If you take the blower off then install the engine you might not have to cut it as much,It didn't hurt anything on mine and didn't look bad at all.Hood scoop was pretty tall.
Also I had a Barry grant electric pump mounted on the fire wall .It had a hard time sucking fuel. I ended up mounted it as low as I could on that fire wall close to the floor by that drain hole .If I was low on fuel it wold lose prime. I also change out the pick ups inside the fuel tank to a # 10,
Also on the stock motor mounts ,the TQ of the motor cracked the stringer on the Port side from the motor pulling up on it in that area, it also cracked on the outside in that area.I am thinking that this was causing a hook in the hull on that side from the TQ.I never broke a mount though.
I still have the mirror I could trace out the hole if ya need.To cut the hole I took carboard and cut it to fit in to the lip in the compartment like the hatch sit in taped it in the back like a hinge ,I got a closer cut this way ,also had to cut more out of the back to clear it
If ya need any help just hollar
Rob
not a digital pick,it large though
http://www2.filehost.to/files/2006-1...clear_pick.jpg
