Drive spacer question for 29 scarab single >
Old 12-22-2008, 09:41 PM
Default Drive spacer question for 29 scarab single
I would like to know if anybody with high horsepower use's a drive spacer ? And if so what size with a 4 blade prop ?
shotime113 is offline
Old 12-30-2008, 04:59 PM
scarabman's Avatar
Originally Posted by Jeff P31
Can not see needing spacers on a single . just my .02
Agreed. If anything I would be thinking shorter!
scarabman is offline
Old 12-31-2008, 12:46 AM
I have 900 hp. And as the tourque come on the prop cavatates I am trying to spend a 30 pitch bravo 4 blade.
Ant thought any help would be great Thanks....
Old 01-01-2009, 06:15 PM
Thanks Jeff , But I only have a single. And the boat runs very well with some of my fat friends in the back seat. So would that mean that I need a spacer in there? And a bravo 1 for now. imco xr drive next month.
THOUGHTS ????
Old 01-10-2009, 03:22 PM
hullofjustis's Avatar
I had a 29 single engine with 820hp with a 1 inch shorty and had no problem getting on plane with a 26 bravo one spinning 5800 rpm what are turning rpm wise?
hullofjustis is offline
Old 01-10-2009, 11:51 PM
I have only spun the motor up to 5200 and the prop slipage is horable. What was your prop slipage ? And was that a 3 or 4 blade prop ? And thank you for responding:cool :
Old 01-11-2009, 01:09 AM
4200 rpms @ 56 mph with a 30 pitch prop. the propellar lifts the rear of the boat when hose power is being produced.
Old 01-17-2009, 03:40 PM
at what rpm range is peak horsepower and peak torque? my prop was 26 pitch 4 blade if you are using a 3 blade it will never work with that much hp in that heavy of a boat in a single engine application. where is your propshaft in relation to bottom of the hull?
Quick Reply: Drive spacer question for 29 scarab single
