its a 90' 22' foot boat, so I am thinking that a survey may b more than your willing to pay. true they have problems with wet transoms/stringers. you need to get a plastic hammer (yellow tip) and get in there and start tapping, (transom and stringers)it should sound solid, if it starts sounding like a dull thud instead of a bright tap, run. look at the motormounts..any saging into the stringer? i you can get away with it, pull one of the lag bolts on each side on the motormounts...is the whole dry? is the wood solid??pull the drain plug and stick a srew driver in there..if you can push the tip into soft wet wood, run. get a piece of skinny solid rod (like a car antenna bend it so you can stick it behind the inner transome plate and push sideways in the transom. you should not be able to poke into it. is the glass your seeing a fix or are you looking at the original tabbing? wen was that last time bellows/gimble bearing an impellor were changed? if there are any soft spots on the floor, theres probably soft spots on the stringers.
Screaming Beaver Yacht Club
twin 188 hp monster 5 liter motors, 1288 hours on the meter propelling a 30 year old resin bucket at ballistic speeds... 47.8 on the gps!!! one bad mofo. seriously.
