Go Back   Offshoreonly.com > Owner's Forum > Scarab
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 02-08-2010, 09:09 PM   #1
33 Scarab AVS
33 avs dry exhaust?
I was thinking of running dry exhaust using my gil / merc stuff and 8 inch turn downs for mufflers. What I'm worried about is reversion. the avs sets so low in the water that if I have 3 or 4 people sitting on the back the exhaust is half under water. I know in theory with the turn downs all ready deep under water that would prevent a flood of water from a roller getting in. But would I have other problems? Thoughts?
nxfirebird is offline   Reply With Quote
Old 02-09-2010, 10:17 AM   #2
Just another freak !!!!
96 Scarab P31
You will burn the rubber boots off all the exhaust if you run it completely dry.
Jeff P31 is offline   Reply With Quote
Sponsored Links
Old 02-09-2010, 12:02 PM   #3
just wondering what is the advantage to runnin dry
humpster is offline   Reply With Quote
Old 02-09-2010, 12:37 PM   #4
2000 33 Scarab AVS
Quote:
HP, and it sounds bada$$ besides
In the stock exit location you will need jacketed tips so that the water dumps at the same point as the exhaust exits in order to avoid the previously mentioned burned flappers. I run the Eickert cast headers dry to jacketed tips with flappers and have never had a reversion issue.
scarabman is offline   Reply With Quote
Old 02-09-2010, 05:24 PM   #5
33 Scarab AVS
Cool, I've already got to rebuild my tips cause the internal flappers are burned out. So I could build then how ever I need to, jacketed etc., that's why I'm thinking dry. BUT kansas has a 92 db law at idle, hence the turn downs.
Scarabman, what's your boat run, what power?
Old 02-10-2010, 06:23 AM   #6
2000 33 Scarab AVS
I have the Volvo 600 DPX set-up. The boat runs a shade over 92 factory stock on a good day. Everyday speeds are around 90.
The Exhaust tips I have are made by Corsa. They do not fasten to the transom. They are fastened to the headers directly. Just throwing that out there becuase you will have to modify your transom just slightly since you cannot use a rubber exhaust hose connection if you go dry.
As far as decibels go, NJ actually has a full time muffler requirement so I do actually have clamp-on mufflers on mine. They keep at about 94 db at idle. They did cost a little top speed but I do have 2 little kids that go boating with me anyway.
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
