Scarab 26 Prop Advise
Scarab 26 Prop Advice
Does this sound like I am running an incorrect prop?
I've got a 1996 Scarab 26' with a 454 that I thought would be faster than it is. I should top out faster than 38mph right??
I can't recall the prop diameter however the pitch is 19 and is three bladded. Advice? What are other 26' 454 single engine unmodded owners seeing speed wise?
Thanks in advance.
Thanks in advance.
I have a few 21 pitch props, including a 21 mirage plus if you want to try it out, we have been hanging around just inside the Boynton inlet lately at a sandbar real close to a good spot to prop test. We'll probably be back out in the next few weeks, if we are out I'll put it on the boat, just stop by and we will mount it up on yours and go for a spin. Were you turning 4600 when you ran 38MPH?
I have a scarab 22 that had stock power at one time and that is what i ran with it, my was labbed , with a 19 pitch will be on the rev limiter . I run a labbed 30 with the power i have know
scott
scott
