Like Tree0Likes
38 scarab avs
Old 09-29-2017, 10:34 PM
5050's Avatar
My Boats: 2001 38 AVS Scarab
Problem is that you are loosing power up top. This my Zz572s/620 engine in 99 38 Avs. 30 pitch 5400/5500, 84/86 mph. Wouldn't pull passed that rpm. Your numbers are about the same.
5050 is offline
Old 10-02-2017, 10:12 AM
Trade Score: (28)
Baja226sport's Avatar
My Boats: 38 Scarab Avs 700 Whipple & Baja 250 ES
Quote:
My sheet shows horsepower climbing all the way through 5800.
Baja226sport is offline
Old 10-03-2017, 07:20 AM
5050's Avatar
Yes so did my Zz572s . 5hp increments with torque falling quickly, u probably need 700 at 5400 to notice a difference . That's not going to keep spinning prop faster it's not a car on flat ground. You had 19hp increase in 400 rpm engine might be making 700 but it only has 680 usable hp at 5400.
5050 is offline
Old 10-04-2017, 10:41 AM
Geronimo36
Panther's Avatar
My Boats: 36' Apache Warrior / 22' Apache Scout
Hmm.... looking at the numbers you guys have posted here... I'm a little dissapointed in what this AVS I just built some 725hp NA engines for is going to run for top speed. I was hoping closer to 90mph but it seems like mid 80's is where it will be.
Baja226sport, is this Paul F.? Looking at your peak torque, I'm wondering more cam duration might be better for your setup. Looks like it plateau's around 4200. If you're spinning 5500/5600 WOT and even though the HP number are climbing (they usually do with blowers) I usually want to cam it so the peak torque range will be a little higher (say 4500-4800) from the setups I've put together.
File Type: pdf
Panther is offline
Old 10-05-2017, 10:18 PM
5050's Avatar
yeah I donít think u have enough to get to next barrier, either need more cam or possible retard cam 2 to 4 degrees and move torque higher up in rpm to push the prop some more. Probably 30 pitch 5500 as u are now.
5050 is offline
Old 10-11-2017, 04:26 PM
Geronimo36
Panther's Avatar
I usually prop something like this 800-1000 rpm above peak torque so figure 5700-6000. It has bravo's so I can't lug it either.
Panther is offline
