Scarab 29 with 500 EFI
[QUOTE=hullofjustis;4144019]
I want to try a imco -2 inch next year.
What prop did you have at this time 4 blade or 5 blade?
And what drive ratio?
I have a 29 single with a 525sc and i was run 68-70 mph gps, now i have build the engine with Bob Madara custom grind roller cam, ported alluminium head, 8:1 comp ratio, 468 ci block, BM 250 blower, twin QFT 850 marine carb at 9-10 psi boost with water/methanol injection estimate at arond 800hp runing now 80 mph gps turning a BBlade 26p lab at 5700 rpm.
With std height bravo drive that the center of prop shaft is at 7,375'' below the bottom of the hull.
In 2-3 foot chop the boat start to chine walk.[/QUOTE
I HAD 825 HP 5900 -6000 RPM -1 IMCO LOWER AND HAD THE BOTTOM BLUE PRINTED AND DID NOT CHINE WALK AT ALL, YOU MAY WANT TO CONSIDER RAISING THE X DIMENSION OR BLUE PRINTING THE BOTTOM
I HAD A 26 4 BLADE BRAVO ONE 1.5 GEAR RATIO, NOW THAT I THINK ABOUT It I WAS USING 4.5LB BOOST ON THE DYNO and DROPPED TO 3LBS WHEN I PUT THE ENGINE IN THE BOAT. SO IT WAS PROBABLY ONLY MAKING 775HP. 7.375 below the bottom is really low but normal for a boat built then. you may even consider putting a -3 imco on or an imco extension box if you are looking for top speed. prop shaft i do not recall where that was on my 29.single, i have my twin engine scarab panther setup to be 3 1/4 below the bottom with std. length bravo and 1 1/4 below with shorties.
neutral trim. or propshaft at the same angle as the hull. tak a straight rule hold it next t the bottom (lowest point) of hull and put the propshaft at that same angle and drop a tape measure from rule to propshaft center
-------------- like that top line is lowest point of v on a single engine lower line is propshaft
you can measure one hull and put the identicl boat next to it and it more than likely will be different .propshaft height that is
