Does Formula install this?
Charter Member #415
Re: Does Formula install this?
Those are Mercruiser parts,any Merc dealer could get them for you. I have part #'s somewhere if you can't get a local guy to look them up for you. Robert
Charter Member #415
The quick connector is #22-861405,the end you put on the hose to flush is 22-861406. The t-connector that goes into the water line is 22-861339T. Clamps and any additional hose is available locally. I don't use the bracket that bolts it up,tystraps work fine,and I don't use the little blue plastic cover cause it won't stay on anyway. Got it all in stock but you should be able to get it locally with those #'s. Robert
Originally Posted by offthefront
Does that go to the suction side of the sea pump ? Should be abble to work on 454 app ?
Charter Member #232
Glad to see if you need a tough question answered you know were to come Brian
Put your best foot forward!
Charter Member #415
The bracket is Merc part #861242,List $4.20. Atlanta and Fond Du Lac branches have them in inventory. And don't call me Mf,somehow just doesn't sound right
