What carb came on 420 HP Engine?
I'm having a hard time identifing my carb. Does anybody know what carb came one th 420 hp from Mercruiser. I know its a holly 4 barrel with no choke?
Re: What carb came on 420 HP Engine?
This carb has no choke bowl so I cant find the serial numbers. The only number i found was 8543 with a 4 under it on the top right hand side of the float housing?? Mercruiser said it should be a 4781 but when I go to holly the 4781 looks different. ??
9022 is correct.
Here is the basics on the set-up from Holley. I don't know
if Mercury rejeted these or not:
800 CFM 4150 Marine
Front jets: 72
Rear Jets: 87
6.5 powervalve in primary
Compare to what you have now in the carb. The guys are
right, you may not have the factory carb.
OR
800 CFM 4150 Marine
Front jets: 72
Rear Jets: 87
OR
