Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 07-15-2005, 06:01 PM
Hydrocruiser's Avatar
Arrow Marine Lubrication
I thought we should have one thread on nothing but oil and lubes and keep everything in one place for easy reference...so let the thread begin...
The most asked question are oil filter cross-reference..here is the list i can update it as time goes on.
Oil Filter f/ most Mercruisers
FYI:The thread type on the filter is 13/16-16.
Fram: PH5, HP4, DG5, PH13 (no anti drainback) Pureolator: L34631
Purolator Pure One: PL34631
AC: PF1218, PF932
Motorcraft: FL-12A
NAPA: 1060, 1060gold
Wix: 51060
Wix Racing: 51060R, 51061R R= Racing
K&N: HP3002
Baldwin: B1428 (Top Rated)
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mercruiser: 35-802885Q
Mobil 1: M1-302 or M1-111
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
Hydrocruiser is offline
Old 07-15-2005, 06:04 PM
Arrow Re: Marine Lubrication
I received a question today regarding which oils get up to temperature faster. Here is an opinion:
An engine will get up to operating temperature faster with a thicker oil because the oil doesn't absorb as much heat as quickly. So, the enigne is warmer faster because the oil isn't absorbing the heat. As the engine gets warmer, the oil will absorb more heat, but not as fast as thinner oil.
A thinner oil will absorb more heat quicker, not allowing the engine to get up to temp as quickly.
So, I think the answer to this question would depend on many variables. Engine, oil capacity, volume of oil being pumped, load on the engine, etc... One engine may get the oil up to temp quicker with a thin oil while another may get the oil up to temp quicker with a thicker oil.
Old 07-15-2005, 06:11 PM
Oil flow and pressure dynamics. I think we need to understand some of this to have intelligent discussions pertaining about oil pressures with various viscosity and types of oil so here goes:
I am going to bring up the constant flow pump concept. First, it goes back to the principal that doubling the pressure of the same weight oil does not exactly double the flow but it is close. Also doubling the RPM for the same reason does not exactly double the flow but again it is close.
This shows the problem best:
(A) For a 30 wt oil at operating temperature:
RPM....Pressure..Flow
1,000......20 PSI....1
2,000......40 PSI....2
4,000......80 PSI....4
8,000... 160 PSI....8 The maximum flow because of the oil pop off valve at 90 PSI will be 5
(B) For a 30 wt oil at operating temperature
and a higher output oil pump:
1,000......30 PSI....1.5
2,000......60 PSI....3
4,000....120 PSI....6 The maximum flow because of the oil pop off valve at 90 PSI will be 5
8,000... 240 PSI....12
If we stick with the same weight oil and increase the oil pump output we will increase the pressure and the oil flow too. If we double the oil pump output we will double the pressure and we will double the oil flow.
Old 07-15-2005, 06:17 PM
Default Re: Marine Lubrication
Additives available for use in an oil/lubes and what they do:
Here is a comprehensive list (best you'll find outside of the lab) of multifunctional additives and their functions. Notice the same chemicals and compounds perform more than one function.
Multifunctional Additives (in Alphabetical Order) listed as to Functional Agent, additive category, general or specific chemical compound, and how it works, respectively.
Antifoamants or foam inhibitors (Protective Additive): polymers such as silicone polymers and organic copolymers of the silaxane's; creates a lens that reduces the bubble's surface tension.
Antioxidants or oxidation inhibitors (Protective Additive): ZDDP, ZTDC, Moly TDC, Antimony TDC, aromatic amines such as organic tolutriazoles, thiadiazoles, diphenylamines, olefin sulfides, carboxylic acids; decomposes peroxides and terminates free radical reactions. Increases temperature of base oil at which base oil may tend to oxidize. Oxidation of oil promotes polymerization of sludge particles and increases viscosity.
Anti-Wear and Extreme Pressure Additives (Surface Protective Additive):
ZDDP, ZTDC, Moly TDC, Antimony TDC, Organic Sulfur-Phosphorus-Nitrogen compounds, Borates and Borate Esters, Tricresyl Phosphates, amine phostphates, and other phosphate esters, Chlorine compounds, and lead diamylcarbamates, lead and barium naphthenates, sulfurized olefins; protective film interacts at various temperatures and pressures to provide either a plastic interface or to provide a compound which shears at the surface.
Demulsifier (Performance Additive): hydroxyalkyl carboxylic esters, alkenlycarboxylic esters; keeps water separated from lubricant.
Detergents (Surface Protective Additive): metallo-organic compounds of sodium, calcium, magnesium, boron phenolates, phosphates and sulfonates such as alkylbenzene sulfonic acids, alkylphenol sulfides, alkylsalacyclic acids; Lift deposits from surfaces to keep them suspended.
Dispersants (Surface Protective Additive): Alkylsuccinimides, alkylsuccinic esters (alkenyl succinimides); chemical reaction with sludge and varnish precursors to keep them acid neutralized and to keep them soluble. Detergent-dispersants often are the same chemical or come in compounds to accomplish the combined function(s).
Emulsifiers (Protective Additive): Polyisobutylenesuccinimides, alkenylsuccinate ester/salts. polyester amides, alkyl aminoesters; promotes a stable emulsion or mixture of oil and water.
Friction Modifiers or Friction Reducers (Performance Additive): Organic fatty acids and amides, lard oil, high molecular weight organic phosphorus and phosphoric acid esters such as Tricresyl Phosphates, ZDDP, ZTDC, Moly TDC, Antimony TDC, family of diphenylamines and amides, and olefin sulfides. Reduces coefficient of friction formulated lubricant in the boundary lubrication regime. Some VII's also provide friction reduction.
Metal Deactivator (Protective Additive): ZDDP, ZTDC, Moly TDC, Antimony TDC, family of diphenylamines and amides, and olefin sulfides, heterocyclic sulfur-nitrogen compounds; inhibits corrosive effects of oxygen with metals and decreases metal interaction with oxygen compounds to reduce oxidation of oil.
Oxidation Inhibitors (See Antioxidants).
Rust Inhibitor (Surface Protective Additive): Barium sulfonates, amine phosphates, phosphordithioates, sodium thizoles (for coolants),
Pour Point Depressant (Performance Additive): polymethacrylates (PMA's); reducing wax crystal formation and increases solvency of oil at low temperatures. May be part of VII package.
Seal Swell (Performance Additive): nitriles, specific esters, organic phosphates and aromatic hydrocarbons. Increases volume of elastomeric seals.
Surfactants or Surface Active Agents (Protective Additive): family of diphenylamines and amides; usually part of the antioxidant package. Also provides enhanced friction reduction and allows oils to "climb" or spread on and over surfaces. Decreases but does not destroy surface tension
Soot Control or Soot Inhibitor (Protective Additive for diesels): Organic Barium compounds; keeps soot in suspension. Usually part of the dispersant package in diesel formulations.
Tackifiers (Performance Enhancement): copolymers of ethylene and propylene; helps oil cling to surfaces. Very useful in geared machines such as transmissions, differentials, and chains.
Viscosity Index Improver or Viscosity Modifier (Performance Additive): Olefin copolymers (OCP's), hydrogentated styrene-diene copolymers, styrene esters, polymetharylates (PMA's), mixed alkyl methacrylate-vinyl-pyrrolidines, aminated ethylene propylene, mixed alkylmethacrylate ethylene/propylenes; reduces viscosity change with temperature. Increases viscosity of base oil as temperature rises when base oil tends to thin. Some VII's may also act as dispersants by incorporating dispersant compounds.
Old 07-15-2005, 06:19 PM
Oil Technical data 2005
This site is closed that i previously posted..so I will provide it as needed.
Old 07-15-2005, 06:20 PM
Bob's and others Oil abbreviations:
AB Alkylated Benzene
ACEA Association of Constructors of European Automobiles
ADBV Anti Drain Back Valve
AN Alkylated Naphthalenes
API American Petroleum Institute
ASTM American Society for Testing and Materials
ATF Automatic Transmission Fluid
AW Anti-Wear Agents
Auto-Rx Auto-Rx
BC Belgian Castrol 5w40
Base Oil Groups link to Chevron page
BITOG BobIsTheOilGuy forum
COC Cleveland Open Cup
COF Coefficient of Friction
CR Compression Ratio
D1 Delvac 1 synthetic HDEO
DOHC Double OverHead Cams
EP Extreme Pressure
FP Fuel Power
FM's Friction Modifiers
GC German Castrol
HDEO Heavy Duty Engine Oil
HOAT Hybrid coolant, Hybrid Organic Acid Technology
HTHS High-Temperature High-Shear
LC Lube Control
M1 Mobil 1 synthetic oil
MMO Marvel Mystery Oil
MoDTC Molybdenum DialkyldiThioCarbamate
Moly Molybdenum
MTF Manual Transmission Fluid
ND Non Detergent motor oil
OCI Oil Change Interval
OHC OverHead Cam
OHV OverHead Valve
PCMO Passenger Car Motor Oil
PAO PolyAlphaOlefin
POE PolyOlEster
PCV Positive Crankcase Ventilation
PTFE PolyTetraFluoroEthylene(TEFLON)
QS Quaker State motor oil
RP Royal Purple motor oil
RBOT Rotating Bomb Oxidation Test
RTS Rotella T Synthetic 5w-40
SAE Society of Automotive Engineers
SbTDC Antimony DialkyldiThioCarbamate
SX-UP/Sucks-Up SX-UP/Sucks-Up
TAN Total Acid Number
TBN Total Base Number
TSB Technical Service Bulletin
TOST Turbine Oxidation Stability Test
UOA Used Oil Analysis
VOA Virgin Oil Analysis
VI Viscosity Index
VII Viscosity Index Improvers
ZDDP Zinc Dialkyl Dithiophosphate
Z-Oil German Castrol(GC)
Old 07-15-2005, 06:22 PM
2005 Up to date BIOTG Virgin Oil Analysis results:
http://www.bobistheoilguy.com/voalibrary.html
Old 07-15-2005, 06:26 PM
Oil Filter company #'s
Filter Companies contact number:
AC Delco: 1-800-233-3526
Punch 1, then 4.
Baldwin: 1-800-882-5394
Punch 1, then 2.
Champ: 1-800-882-0890
Direct line
Donaldson: 1-800-374-1374
Punch 2 for cross ref, punch 3 for technical
Fleetguard: 1-800 223-4583
Punch 1 for cross ref, punch 3 for technical
Fram: 1-800-890-2075
Punch 1
Purolator: 1-800-526-4250
Direct line
Wix: 1-800-949-6698
Punch 4
Old 07-15-2005, 06:27 PM
Who makes what filter?
Updated List;
Fram
Fram Extra Guard (std)
Fram Tough Guard (different media?)
Fram X2 (Silicone ADBV, Fuzzy media)
Fram Extended Guard(same as the X2)
Mileguard (Jiffy)
Honda (although some are alleged to be made by Filtech)
Chrysler line up except for the Cummins
Penzoil
Deffense
Canadian Tire
Champion Labs
Bosch
Car and Driver
Deutsch
Mobil 1
STP
SuperTech
K&N
Valvoline filters
Mighty
Service Champ
Lee
AutoZone Value Craft
Some AC Delco
VW (some)
Warner
Luberfiner
Trust
Wix
Carquest blue
Carquest red
Napa Gold
Napa Silver (lower quality with nitrile ADBV)
Kralinator (in Canada)
ALLIANCE (Freightliner aftermarket)
Purolator (Arvin Meritor)
Purolator premium plus (nitrile adbv)
Purolator Pure One (silicone adbv, different media)
Havoline
Maxlife Valvoline (some)
Group7
Promotive
Powerflow
Quaker State (less media)
Advanced Auto Total Grip. (less media)
Pep Boys Pro Line
MotorCraft
Superflo
Denso
Toyota
Mann+Hummel
Mann
Volvo
Clarcor
Baldwin
Hastings
Amsoil
Casite
Old 07-15-2005, 06:28 PM
Oil Filter Study:
http://www.oilfilterstudy.com/
Quick Reply: Marine Lubrication
