Gas Tank
NO WAKE ENFORCER
Gas Tank
I Need A New Tank, I Posted In The General Section But No Replies Yet
Any Suggestions?
I Would Like A Plastic One
Thanks Pj
Any Suggestions?
Thanks Pj
Re: Gas Tank
I'm surprised to hear that you need a new tank...what happened?The original tanks were welded aluminum I believe....manufacturered by Florida Marine tanks. They are still around, how about an OEM replacement? http://floridamarinetanks.com/
Why would you want a plastic tank? Just curious.
NO WAKE ENFORCER
Re: Gas Tank
chuck the cost is my first reason, second is I read that they are better, third reason would be cost.....
what do you think?
they are welded aluminum it filled my liitle bilge in the cabin three times with gas yesterday it has had a slow leak for about three years, it nevers gets in the engine compartment just the dam cabin. I have already taken out the carpet it was toast
what do you think?
Re: Gas Tank
I just replace a 24 year old tank in my 22 Donzi. It was aluminum. We aren't even sure if it was leaking, I think it was coming from around the sending unit. Anyway, pulled the deck off, and it wasn't going back on without a new tank. If the next one last 24 years, I'll be taking a dirt nap by the time it needs replaced. The place that changed mine out was also doing another Donzi just like mine at the same time. I picked mine boat up on Saturday, and there was a $125 disposal fee for the tank! I told him to take that off the bill, and throw it on my truck, and I'd dispose of it myself. Saturday, I was talking to another Donzi owner, and he said he sold his old one for scrap aluminum for $50, but you had to cut it in half first, so the scrap yard knew there was no gas left in it. I the shop loaded the one out of the other boat, I know, but it didn't matter to him. I was going to cut it in half today, so I filled it with water first to be sure there were no gas fumes left in it to blow up when I got out the die grinder. When I filled it with water, it wasn't leaking a drop. Deb told a freind of hers that I was going to scrap it, and he said not to let me cut it, because he wanted it, and he'd give me $50 for it. The new one cost $548 or something like that plus shipping, and it was a Florida Marine Tank. It took five weeks to make it, they don't keep any specific tanks in stock, hell, they'd have to stock thousands of them. Anyway, I'd go back with aluminum if I were you. They are tried and true. I've heard of plastic tanks splitting wide open.
Here's the tank on my driveway full of water today.
48 gallons, I believe it is.
Re: Gas Tank
Btw, notice that the new tank has six tabs, where the old tank only had two. I had it completely plumbed for half inch lines, including a bigger pick up tube. That's for future power changes.
NO WAKE ENFORCER
Re: Gas Tank
thanks cuda
5 weeks is a long time, I am 99% sure it is leaking like I said there wasnt any gas in the engine compartment just the little bilge in the cabin, and it has a new sender gasket., I can get a plastic one that holds 55 gal that is almost a direct fit just not as long for $319 and have it in a
week or less
Cuda I checked the drive like you said and it was about 1/2 a quart low topped it off and used it all day yesterday without a problem.. thanks
week or less
Re: Gas Tank
what do you think?
what do you think?
Once you pull the old tank it will be interesting to see where the leak is. I would be amazed if it is at a seam. Have you checked and double checked the pickup and vent lines/fittings?
Re: Gas Tank
Originally Posted by chuck21401
I don't know which tank would be better--plastic, aluminum or some other material. But I think quality and strength would drive my decision over cost. One other thing to research....gasoline now has more ethanol content...will plastic tanks hold up over time?
I agree with Chuck, quality and strength, considering the intended use of these types of boats.
NO WAKE ENFORCER
Re: Gas Tank
Originally Posted by cuda
Did you check the o rings?
my guy is checking the drive leak out should know something soon
