575sci Lower End...What RPM?
Aware of the rev limiter...most likely changing heads/cam and would like to know what the bottom can handle. I have also read you do not want to bounce MEFI3 off the limiter so it is going to get bumped up for that reason also.
JRider, what are you running for a prop and drive? have you ran a 5 blade on your boat? what kind of speeds are you getting with the 575sc? I have the same boat, just wondering how others are running.
thanks
larry
thanks
larry
Dustin
1.5 XR drive. The prop was originally a 30 bravo repitched, lab finished and stamped 32 by merc. I personally feel it is more like a 31 due to slip numbers that seem unrealistic for the hull. I am hitting 93 fairly easily. I dont believe a five blade would do much for me except overload an already stressed XR. However I would love to try a hydromotive quad 4.
thanks
larry
