Anti-freeze leaking from 496 >
Old 01-28-2004, 04:36 PM
Default Anti-freeze leaking from 496
I went out the other day to charge the batterys and noticed that the anti-freeze resivoir was empty .I did some looking around the bilg and found the missing anti-freeze . I started checking around the engine and found anti-freeze leaking around a seal that connects the heat exchanger to the crossover tube . Has anyone had any similar problems on a 496 Mag HO ? The engine is still under the factory warrenty,but the dealer is over an hour away so I was thinking about fixing myself . Is this an easy fix . Or do you think that there are bigger problems other than a bad seal ?
nofed is offline
Old 01-28-2004, 05:13 PM
force 320
I just bought a new set of these last summer and also have coolant leaks, I found that a lot of the hose clamps were not as tight as they should be and tightened them up , seamed to help. I haven't seen my heat exchanger leak yet. any one else?
Old 02-06-2004, 05:12 AM
AKA NoMoBoatin
Default leak
had the same problem and was told it was the seal in the pump up front so i installed a new pump but it still leaked as yours did waiting to de-winterize to fix.
docmanrich37 is offline
Old 02-06-2004, 07:26 AM
sterndrivespec's Avatar
you should have your dealers contact mercruiser about this.we had a customer that ruined an engine for the same reason.
sterndrivespec is offline
Old 02-06-2004, 02:39 PM
Rough Seas Lie Ahead
Reckless32's Avatar
Ruined how and why?
Reckless32 is offline
Old 02-06-2004, 02:43 PM
Kentz
There was a Merc. recall on this, sorry I don't have access to the TSB#. Most prominent in salt h20 use.
Old 02-06-2004, 02:49 PM
Kentz
OK, so I had a copy here at the office in my breifcase, who knew
MERC TSB # 2002-04 "Water Rail Connectors and Fittings"
could this be it ?
Old 02-06-2004, 03:44 PM
Thanks for the help . Maybe I should talk to the dealer before I attempt to fix.
nofed is offline
Old 02-06-2004, 04:06 PM
AKA NoMoBoatin
i checked my recalls and isn't any on it.
Old 03-11-2004, 07:10 AM
rv
Did you fix your leak on this? If so, what was the cause/solution.
Rick
rv is offline
Quick Reply: Anti-freeze leaking from 496
