Go Back  Offshoreonly.com > Owners Forum > Sonic
Speeds of 42 Sonics >
Speeds of 42 Sonics
Speeds of 42 Sonics
Old 11-14-2004, 07:42 AM
rv
Default Speeds of 42 Sonics
Can someone provide me gps speeds for a 42 Sonic and what power/drive setup they have. Looking for ~80mph and would like to know how much power it will take.
Also, any tricks on this hull to improve speed and how much was gained with the change, i.e. weight shift, extension boxes, bottom work, etc.
Rick
rv is offline
Old 11-14-2004, 08:40 PM
NJSONIC's Avatar
Default Re: Speeds of 42 Sonics
RV,
I had a 2001 358 with 500efi's it ran 79mph GPS. If you have a 2002 or newer you will have the infusion layup which will save approx. 10% in weight. You will need at least 800hp per engine to get in the 80's if my figures are correct. Our new 386sts with 800hp per engine will be in the 90's but hoping to be just in the triple figure. Hope this helps.
NJSONIC is offline
Old 11-15-2004, 06:42 AM
Quiet Storm's Avatar
RV
My 01, 386 with 575 SCi's, XR drives with Imco boxes runs 83 GPS. The 575's are rated at 550 HP. I think three HP 500's would get you close or above 80 in the 42.
Quiet Storm is offline
Old 11-15-2004, 08:01 AM
rv
Thanks for the response, anyone else...
rv is offline
Old 11-15-2004, 09:31 AM
LapseofReason's Avatar
My 2000 42 with 500 efi's bravos 24p bravo 1 props all stock, empty with just 2 guy's 1/4 tank of gas in salt water went 75.3 gps. Installed generator all the crap you need in freash water the best I got was 72.6.
LapseofReason is offline
Old 12-02-2004, 12:21 PM
captwk's Avatar
I'm got 72.2 with 26 pitch P5Xs but we are still at 19% prop slip. Julie from Throttle Up is working with me. Can't say anything but great things about them. Waiting on Sonic to send me a drive spacer to get the props in the water better.
2005 Sonic 42SS
525 EFIs
Bravo XR ITS Drives
captwk is offline
Old 12-02-2004, 05:46 PM
26sonic's Avatar
captwk how much of a spacer you going to? my firend with 358 500 efi with its had to go 2 full inches to get dialed in correctly!
26sonic is offline
Old 12-02-2004, 09:52 PM
I have a 1998 42 that had the mer 800SC #6 drives, we are now going with injected 1100's. I hope it hit in the mid 90's, it was runniing in the mid 80's
SSTahoe is offline
Old 12-03-2004, 01:47 PM
Charter Member #37 /Moderator/Platinum Member
vagrant's Avatar
Rick I went through my motors 2 years ago there are 509's 585hp each. I am turning a stock 24p bravo one at 5100rpms I am at 73 gps. 1997 42 Sonic with generator.
David
Champagne taste on a beer Budget
C. P. B. A. Carolina Power Boat Assoc
vagrant is offline
Old 12-03-2004, 07:12 PM
RJ1340's Avatar
2000 42 sonic, 750s, xrs, 80mph
RJ1340 is offline
Quick Reply: Speeds of 42 Sonics
