Anyone using Morel Lifters?
I hate the winter!!
Re: Anyone using Morel Lifters?
I am using Isky hydraulic roller lifters. When I ordered my cam and lifters, I was told by an Isky tech. that they are Morel lifters.
I hate the winter!!
I have not got a chance to use them yet. I just built this motor. It only has dyno time on it so far. I have heard good things about Isky or Morel Lifters. I hope they work out.
MarineKinetics
Morel is a tier 1 supplier so there is a good chance that many of you may have seen their product branded with other suppliers names. The engineering on these pieces is outstanding as evidenced by their users (John Force/McLaren Engines/Top Truck and Busch Teams.). I will have a technical sheet available right after PRI with some amazing durabliity testing results.
Bob
Bob
MarineKinetics
Tomcat,
These lifters are manufactured to very tight spec tolerance and depending on spring pressures and valvetrain weight will extend the useable range.
Bob
Bob
Tomcat,
The Morel uses their own petal valving in the body of the lifter. With this and the tight tolerances that Ed is able to hold, yes the lifter will take more rpm then other hyd. roller lifters. On the the solid side, I have used the stuff for years now with NO failures due to mfg or lifter fatigue. If Isky is admitting they are using Morel as a supplier then that speaks boat loads of Morels quality.
Chris
Chris
