CMI Blowout!  OSO Group Discount >
Old 11-06-2002, 03:46 PM
Sean's Avatar
Default CMI Blowout! OSO Group Discount--ends Nov 15th!
Guys
I've finalized our pricing for CMIs with Jones Marine and Brian has put together a whale of a deal, so here it goes. Keep in mind that this deal is good through November 15th, so you will need to contact Brian asap to place your order.
$1785 for Platinum Bravo One piece Uni-Tops(satin lower, polished top)...that means if you have a Bravo setup which is standard, these will work and there are no tailpipes needed...(Brian will need measurements to verify)---this is $200 less than Teagues advertised price.
$1785 for Platinum Elbow Top(satin lower and polished top))---this is $200 less than Teagues advertised price. Fully polished, they will be $2175. Bravo tailpipes will be $575 per set. If you have an non-standard Bravo or TRS or Speedy set up, you will need these and tailpipes are extra...Brian esimates between $600-900 per set.
$3225 for Platinum Tube Top, $3465 for polished
All of these deals come with all the hardware needed---gaskets, hoses, hose clamps and header bolts....but no thru-hull tips, port side IGN module plate, stbd shift bracket or EFI control bracket. These items are available at a nominal cost.
Air pump for Silent Choice will be $340 per set and includes switch and air line.
The collector for silent choice will be $1300---regularly $1795
*RJ---1 set std Bravo w/CMI diverters---(need price on diverters)
*JP---1 set Uni-Top Std Bravo
*Sean---2 sets---Elbow Top---with tailpipes
*buca----2 sets---Uni-Top Std Bravo
RickerTX---1 set?
DanB---1 set Tube Top
*Cat---1 set E-Top with tailpipes
BreatheLater---1 set?
Andy Buzz---1 set?
*Madcow---3 sets
*CDaniels---2 sets E-Top TRS
*Zoom(Dean)---2 sets E-Top Full Polish---Speedy Tails
*cashbrain(Jack)---2 sets E-Top---Speedy tails
*boot(Joe)---2 sets Tube Top, no tails.
*rv(Rick)---2 sets---E-Top
*Those who have previously confirmed are marked with an asterisk.
Contact Brian immediately and place your order...mine's already in. I believe he is going to wait until the 15th to do the actual order to CMI. You should also get the diagrams from Brian to get the proper measurements for tailpipes. He will work closely with us to ensure they will be right and promises to provide further discounting.
Call Brian at 704 639 1298
Sean is offline
Old 11-06-2002, 04:18 PM
rpm
I am not looking to buy, I was offering to work up a sale price.
Rod
Old 11-06-2002, 04:26 PM
Sean's Avatar
Sorry Rod, I misread your post.
Also, DanB...that 2600 price you talked about on the other thread seems too cheap for the tube tops...are you sure about that one?
Sean is offline
Old 11-06-2002, 05:05 PM
Charter Member #71
DanB's Avatar
Sean
Yep......Thats the price $2600
Tube split tops..thats the ones with the plate on top with 4 bolts to hold the uppers on....plat lowers..non cool collar, polished uppers, and polished tailpipes for a bravo setup. Had em in my hands. That incl the gaskets, bolts and the rubber tubes. SS log was extra.
Dan
DanB is offline
Old 11-06-2002, 07:00 PM
Charter Member #1528
RiverGirl is offline
Old 11-07-2002, 06:49 AM
jonesmarineinc's Avatar
Post ORDER INFO
To all the people that will be ordering Headers in the next few days, I have thought of a few things to make it a little more easy.
1. Email All the following Information.
2. NAME
3. Address were all parts will be shipped
4. Parts that you will need.
5. If you need build sheets or not.
6. Fax, Phone Number,Email for order conformation.
If anybody would rather overnight certified check than credit card you will save an additional 1% on order. If you are planning to do this email or call. DO NOT leave billing info such as credit card on email for your saftey, please call and give that info to one of our people at Jones Marine.
MAKE CHECKS PAYABLE TO:
Jones Marine Inc.
525 Fox Hollow Farm RD.
Salisbury NC 28146
Email : [email protected]
Thanks again.
Brian Jones
Jones Marine Inc.
jonesmarineinc is offline
Old 11-08-2002, 07:19 AM
Sean's Avatar
Over 500 views and no replies? I thought we did pretty good on pricing...any comments?
Sean is offline
Old 11-08-2002, 07:52 AM
imongo's Avatar
Hey Sean,
If any one wants to order the CMI silent choice, I have a brand new set for a twin for sale. I just got my new ones for my boat and was going to install when I decided to put a Pulse Drive on the boat. Don't need the silent choice for it. I'll sell the whole set for $2600 and include the merc compressor for free! The compressor is used, but works great.
Mongo
imongo is offline
Old 11-08-2002, 11:32 AM
fountain27ho496's Avatar
Default Need help, silent choice question
Was told I would have to give up the silent choice.
Is it possible to add cmi and keep silent choice?
What parts are necessary (all) and cost, total.
Thanks JC.
fountain27ho496 is offline
Old 11-08-2002, 01:44 PM
imongo's Avatar
Hi JC,
You have to give up the Mercury silent choice. You can use the CMI. If you go to CMI's site, you'll see why.
Mongo
imongo is offline
Quick Reply: CMI Blowout! OSO Group Discount
