Go Back   Offshoreonly.com > Owner's Forum > Skater
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-01-2007, 11:27 AM   #41
I had a similiar setup on one of my boats, my engine mechanic hated it. It took too long for the oil to heat up, and sometimes it never got hot.
CM
yahoo is offline   Reply With Quote
Old 10-01-2007, 04:25 PM   #42
The Menace's Avatar
40 Skater, 46 turbined Skater
30 GPM is a ton of cooling for the oil. Water will be fire hosing out the dump. Are you using the same cooler you had?
The Menace is offline   Reply With Quote
Sponsored Links
Old 10-01-2007, 07:11 PM   #43
KNOT-RIGHT's Avatar
Turbine 46 Skater
Quote:
I cant find the original pumps.
If ,im not mistaken he may have been using a 11gpm
flotec.
I just dont like the idea of running plastic housing pumps.
It would be nice to have them setup on a thermostatic control that way you dont have to manualy hit the pump at idle.
The coolers are the ones from the original rigging I
also used them for the pistons combined with canton
oil t-stats.
Do you have oil t-stats?
KNOT-RIGHT is offline   Reply With Quote
Old 10-01-2007, 07:53 PM   #44
KNOT-RIGHT's Avatar
Turbine 46 Skater
What about this guy.
I think these are the ones.http://www.defender.com/product.jsp?...6442&id=160825
Old 10-01-2007, 11:04 PM   #45
1CE
Quote:
Originally Posted by 30Spectre View Post
Menace. Which 46 Skater is yours?
His is a 40 I believe.
1CE is offline   Reply With Quote
Old 10-01-2007, 11:25 PM   #46
OL40SVX's Avatar
Ilmor Outerlimits
Quote:
He also has the Turbine 46 Hell Fire.
OL40SVX is offline   Reply With Quote
Old 10-02-2007, 07:15 AM   #47
999JAY's Avatar
50 Superhawk, 36 Turbine Cat, 32 Active Cat
Make sure you get pumps that are continuously rated.
Most of the pumps you have talked about so far are not meant to be run all day.
It also needs to be self priming and make sure its mounted below the water line, check the max head pumping capacity because the coolers ect. will add back pressure causing the pump to be less efficient.
ENM pumps are self-priming and have bronze bodies and single impellers. They
have 316 stainless steel shafts, which are fitted with NBR lip seals.
temperatures up to a maximum of 90ºC, but can also handle very small soft solids, in
suspension.
999JAY is offline   Reply With Quote
Old 10-02-2007, 08:13 AM   #48
KNOT-RIGHT's Avatar
Turbine 46 Skater
Body Stainless steel
Port Type 3/4" (19mm)
Voltage 12 or 24 Vdc
Motor Brush Life 3500 hrs
Duty Cycle Continuously rated @ 20°C ambient, 20°C Fluid temperature at 2.5 metres of water (0.25 bar) (see Performance Curve)
Weight 6.3 lb 2.88 kg
Old 10-02-2007, 08:16 AM   #49
KNOT-RIGHT's Avatar
Turbine 46 Skater
Designed for bilge pumping, or general transfer duty.
Self priming up to 1.2m (4ft), with an output of 1920 lph (420gph).
Bronze pump heads resist corrosion, bronze bodies feature a reusable O-ring-type end-cover seal.
12vdc.
Available in single or reversible direction
This is the second "water Puppy"
Old 10-02-2007, 08:20 AM   #50
KNOT-RIGHT's Avatar
Turbine 46 Skater
The first one is continuious rated.
However, If you refer back to the cocktail napkin sketch
the application does not require continuious.
The thru hull pickup will provide a large amount of water
at speed.
See at speed bypass.
I would like to interface a temp controller to trip a relay
that would energize the pump at a given temp level.
Maybe something available in Johnson controls
HVAC application.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Reading 101!!!! flylevel General Boating Discussion 5 07-28-2002 10:39 PM
Search Engine Optimization by vBSEO 3.2.0
