Gettin Throttled UP !!!!!
As you know, I am thinking about doing the same thing.
Do you have good baseline data for the current props?
Would you post the current data?
Once you have a chance to run the new props, would you post the new data?
Frank F.
They look great ! did they speak to you at all about changing engine heights? typically , a 5 blade will give more lift and sometimes you need to raise the engine heights to compensate (to put less blade in the water) . Depends on rake . Do you know what rake these are? what are you runing for water pressure rt now ?
