Finally Started Rigging My 32 Skater >
Old 09-23-2011, 06:44 PM
This is just mock-up , soon all parts will be blasted , epoxy prime , straight up Black ureathane ( single stage for those not familar with paint ) but I also lay three coats of clear , this way the shine is a mile deep .
Larry
KEVLARKAT32 is offline
Old 09-23-2011, 08:55 PM
Larry, awesome!
Will you blast the aluminum parts till the aluminum shows? or will you blast the parts just enough to remove surface coat and oxidized surfaces for you to have a stable surface for the epoxy prime and urethane?
noli is offline
Old 09-25-2011, 08:36 PM
Larry,
To summarize, you will have/build the following:
* trim lines in rigging tube
* lower pans have been glassed together
* trim actuator cable in rigging tube
* aluminum limiter can be installed in ram
* kit that includes solid stainless upper pin as well as block off plates
* paint and clear kote the engine exterior
would luv to see these in future pics
noli is offline
Old 09-26-2011, 09:27 AM
Way too much work and it may never get done
Old 09-26-2011, 10:54 AM
Looks good Lar
Baja555 is offline
Old 10-27-2011, 11:23 AM
Larry, any updates on this thread yet?
noli is offline
Old 10-27-2011, 03:39 PM
Selling it ! When are you going to buy a 32 ??
Old 10-28-2011, 01:13 PM
SkaterMike82 is offline
Old 10-28-2011, 04:06 PM
Is the 375 hp a dyno number ? looking good hf...
halffast is offline
Old 10-28-2011, 06:21 PM
They are built by the best , Shaun Torrente ( Mercury F- 1 ) They are around 350 hp with stock Throttle body and 360 + with STR 4 inch TB
