New Skater under construction >
Old 10-08-2017, 05:54 AM
  #61
Zero Patience's Avatar
Boat is progressing. Tony sent a few pictures.
Attached Thumbnails New Skater under construction-08e33f85-a12a-4faa-8c01-9929a6cfce19.jpeg   New Skater under construction-1998c89d-2534-457d-ba8f-32750eb4f1c5.jpeg
Zero Patience is offline
Old 10-08-2017, 08:01 AM
  #62
Originally Posted by Zero Patience
Axles on, fender mounts and fenders mounted, brakes mounted, Spare tire mount built and installed. Brake lines and wiring next.
Awesome job buddy. Can anyone see a hint of color to come on the boat🤔
Double Rigged is offline
Old 10-08-2017, 10:40 AM
  #63
Nice Pair's Avatar
"Very Cool"
Nice Pair is offline
Old 10-08-2017, 11:38 AM
  #64
Thanks guys, its been fun building the trailer. Should be fun on the Boat build.
Old 10-09-2017, 10:29 AM
  #65
Let me take a wild guess..........bright orange?
Skater30 is offline
Old 10-09-2017, 10:32 AM
  #66
Your 30 will be lighter than all the 318s, so it should be faster. As busy as they are back at the factory, I wouldn't expect the build to move too quickly. I don't think they've been this busy with new boat orders since the early 2000s. Looking forward to seeing your project progress!
Skater30 is offline
Old 10-12-2017, 07:55 PM
  #67
We hope to see it progressing as well. We have tubs full of parts here and ready. Kinetic Anamation came thru with the decals, mainly just wiring and trailer brake lines left to do. We need a boat...
Attached Thumbnails New Skater under construction-f4df5da4-a5d0-4fde-a393-c44fb03854e7.jpeg
Old 10-12-2017, 10:02 PM
  #68
What Jack Plates are you using?
AZMIDLYF is offline
Old 10-13-2017, 04:38 AM
  #69
Skater recommended, R&R slidemaste, 3” setback. They wanted the weight as close to the transom as possible. I am following their advise on the weight distribution and CG. The R&R’s have to be dismantled and the internals flipped 180 degrees to make the adjustment nut on the bottom, the Verado steering cylinder is in the way with the nut on top. We would always be adjusting during setup on the trailer anyway. I like how the side rails lock into each other.
Old 10-17-2017, 05:27 PM
  #70
About complete on the trailer, we added lumashore boat underwater lights to it. I had a tough time backing the 28 trailer into tight spots at night when traveling, these should light the way to back up.
Attached Thumbnails New Skater under construction-836c6510-0a7e-418c-b983-2eddae8cc5cf.jpeg   New Skater under construction-0d005820-54e3-46da-ab11-de85ad4c545e.jpeg   New Skater under construction-8989f018-cd0e-4d55-bfd0-39b514dc47a8.jpeg
