small honda generator
Re: small honda generator
Originally Posted by sonicator
did your boat come with the cruisair or did you install it?
I don't have any first hand experience, but I've been told that your insurance won't pay off on any damages if you have a problem caused by a non-marine rated gennie. Check it out if you're concerned about this...
tricky stuff and potentially dangerous. I have factory installed genset and even a wind coming from stern will set off CO detector when its running. Be careful-not worth a disaster.
Originally Posted by East Coast B
I think HiPerf2000 is currently working on installing AC, check with him...
Anyway i just got a Honda 2000 and it ran the A/C, fridge, battery charger all weekend on 2.5 gallons of gas. I put it out on the bow and you could not tell it was even running.
got it for $870 delivered.
Here is a website showing specs of the 7k unit that i bought.....
http://www.marineair.com/pdfs/vr.pdf
I found mine used for $500. By the time i bought the pump and all the water hose, duct work, vents, wiring, breaker, fittings, and sea strainer, i think i spent another $400 (pump is $150).
That's a great price for AC!!! I know how much you must have went through to get it installed, I'm finding that nothing is easy when it comes to retrofitting these boats... Not sure if I'll put AC in at any time, have to wait to see how things go as we begin using the boat for overnighting. I've got a lot of little things to do yet and I'm looking into putting MPI's on the motors, exhaust, props, would like ease of starting and a little more hp. Rough getting the motors started if they sit for a week, other than that, they run perfect. Takes a while with carbs to figure out how much fuel they want after sitting for a while...
