Go Back  Offshoreonly.com > Owners Forum > Sonic
Hydromotive on a 26 >
Hydromotive on a 26
Hydromotive on a 26
Old 03-01-2007, 04:33 PM
Charter Member #300
Shooter's Avatar
Default Hydromotive on a 26
So for sh!ts and grins I'm going to try a 23 Hydromotive I have in the garage this weekend. How do you think it will perform? These are stern lifting props by nature and a 23 hydro shold be about close to a 24 bravo I hear. Maybe it will effect the porpise in some way. I tried this on my old 27 Shooter with a blown 454 once and it felt like I was plowing a field. Bajas do have a little bit of a lip in the tail that Sonics don't.
Shooter is offline
Old 03-01-2007, 07:19 PM
Thats my mission the first of the season is props,I talked to Bret at BBlades and got a game plan,soooo I'm with ya Please post your results.
creeper is offline
Old 03-01-2007, 07:24 PM
We can start with a base line, Shooter what motor,what prop,what speed/rpm.Are you running right now?By the way are you running w/K-Planes or Bennetts?
creeper is offline
Old 03-22-2007, 01:32 PM
Shooter did you test the prop? And how did you make out #s wise?
creeper is offline
Old 03-22-2007, 08:50 PM
Creeper If I'm right your running a 525sci. What prop have you been running. I just built 600 hp 540. I going to start with a 26p hopeing to run a 28. So I'm real interested what you guys do. I'm looking for a 50 mph cruise at 3000 - 3200.
Noise Pollution is offline
Old 03-23-2007, 09:08 AM
Charter Member #1472
Prowler's Avatar
i had one on for about 10 min.like you said it felt like a plow,the only thing that seems to work is merc's 3 and 4 blades.i wouldn't even waste the gas to try it.your best bet is to lab a prop.dave
Prowler is offline
Old 03-27-2007, 05:06 PM
throttleup's Avatar
The Prowler does not like stern lift. Bravo I props will perform better.
Julie
throttleup is offline
Old 03-28-2007, 10:54 AM
Throttle Up/Julie,This is strange I had called you people appox 2 months ago about props for my sonic no answer left msg.No one ever called back.But you people have time to type a line .........
creeper is offline
Old 03-28-2007, 11:10 AM
Julie's right!
hpoffshore is offline
Old 03-28-2007, 11:48 AM
carrboy's Avatar
OUCH!
carrboy is offline
awsomethunder
Active Thunder
27
07-10-2007 09:48 AM
MetraMan
9
09-08-2005 04:31 AM
rtmac669
1
08-07-2003 07:34 PM
John B
1
07-06-2002 09:50 AM
Quick Reply: Hydromotive on a 26
