Quote:
Originally Posted by Plum_Crazy
When I think of toe-in, I think this / \. The front of the drives are closer than the drive shafts. However, some people refer to this as toe-out, which only adds to the confusion.
You are right. Stand with your feet together.
Toes = nose cones
Heels = prop shaft
Toes in (pigeon toed) is - you got it; toed in!
Now read this to get you real confused:
Jim Rohr
"Now if the engines were "toed in" (front of engines closer than rear of engines) it would be normal for a deep-V hull, but these engines were "toed out" meaning the engines were both driving away from center line if looking forward from transom to bow."
I had the same problem the guy in the article did. OSO Steve solved this issue for me after I spent $10Kish in prop testing.
I had Mark Anthony/Mercury Racing rep for 30ish years set mine up. He toed them out a tad to compensate for prop torque since my steering is not super solid. I have outboards so I am dealing with the motor, motor torque, drives and prop torque.
The reason you would toe out a tad is because when a conventional moderate powered V goes through the water- the hull passes, then water fills the void where the hull just was and then the drives pass. The water will rush in to fill that void at an angle since it passes around your hull at an angle.
You are trying to get it so your drives are lined up with the water rushing in to cause the least amount of resistance (think hand out window thing again) but pointing as straight as they can so the most thrust is directed in that way.
Your drives pointing || obviously give you 100% forward thrust, however you may find that by reducing your drag/resistance even if your drives are toed out a tad (not 100% forward thrust) you may be faster than having them ||.
Brownie did the math for me once- some thing like every inch of your drive at 60MPH is over a ton of pressure (I could be WAY off on that but I was amazed at how much it was).
Ah screw it- get some chicks and beer and go boating. Get it close and leave it alone- few degrees in air temp/humidity makes a bigger performance difference than this one-one-tenth of an inch crap!
