Go Back   Offshoreonly.com > Owner's Forum > Sonic
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-09-2009, 09:49 PM   #1
31 SonicSS
Whats it weigh
Ballpark weight of 1997 31ss please. Wnt to tow with 05 Denali XL with 6.0
sonicss42 is offline   Reply With Quote
Old 10-09-2009, 10:16 PM   #2
1995 sonic 31ss
31ss weight
My 1995 31ss Was 8000 Lbs With About 40 Gals Of Gas On A Cat Truck Scale, 10300 Lbs. With Steel Trailer.
MASOMAN is offline   Reply With Quote
Sponsored Links
Old 10-09-2009, 10:41 PM   #3
S.O.B (single O/B) now
t500hps's Avatar
It'll do it....your palms will be sweaty when you get where your going!!
(I pulled a 31 Formula behind a 3/4 Suburban with the 6.0 for a coule summers.)
t500hps is online now   Reply With Quote
Old 10-09-2009, 10:51 PM   #4
1988 sonic 30ss
I have a 2500 Avalanche with a 496 and just towed my 88 30ss 900 miles from wisconsin to ny and it worked my truck pretty good I wouldn't have wanted anything less for that type of distance but the denali should be ok for short trips just keep in mind the factory rating was only like 8000 pounds
andyt25 is offline   Reply With Quote
Old 10-09-2009, 11:42 PM   #5
Plum_Crazy's Avatar
2003 Sonic 31SS
My 2003 31SS weighed exactly 10,000lbs with 1/2 tanks of fuel on a CAT scale including the aluminum trailer. The '03 and up boats are supposed to be lighter. How much lighter, I'm not certain. I pull mine with a 2500 Suburban 6.0L. It can do it, but it's definitely a struggle to accelerate. I upgraded the brakes on the truck and installed all new trailer brakes to be safe. It also has a Wester's Garage ECM tuned for towing. I pulled the boat 1350 miles home from CT when I bought it last fall and put another 1500 miles on this summer without any issues.
I don't know much about the '05 Denali XL. But, it shows up as a 1/2 ton truck. While the engine may have the power to pull 10,000+ lbs., I don't know if the rest of the truck is up to the task. Do you know which transmission you have?
Plum_Crazy is offline   Reply With Quote
Old 10-10-2009, 09:04 AM   #6
upstate31sonic's Avatar
03 Sonic 500 EFI's
07 F-350 6.0 diesel.. full of fuel in truck and boat...4420 steer axel..... 4540 drive axle.... 10360 trailer axles... gross weight of 19320... Cat certified scale
upstate31sonic is offline   Reply With Quote
Old 10-10-2009, 09:29 AM   #7
GO4BROKE's Avatar
2002 Sonic 386
6.0L will pull it just fine, but you will be depending on the trailer brakes to stop decently.
Get a dually. Then you will be ready for the next (bigger) boat too. The brakes on the dually can stop the load even if the trailer brakes fail. My '01 6.0L dually was able to stop both my 31 and my 386 (around 14K pounds) when the brakes failed on the trailers.
GO4BROKE is offline   Reply With Quote
Old 10-10-2009, 09:58 AM   #8
31 SonicSS
Thumbs up Good answers
Thanks for the input, I'll post pics when I get it home and cleaned up.
Old 10-10-2009, 11:52 AM   #9
Wired Nuts
Jim Diesel's Avatar
03 Sonic 31SS w/500 EFI's
When I first bought my 31ss I had a 2500 Suburban with the 6.0l, pulled decent. I just knew I was going to wear it out so I ended up getting a 2500 truck with a Duramax.
Congrats on the new purchase...
Jim Diesel is offline   Reply With Quote
Old 10-10-2009, 01:12 PM   #10
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
Pulled my 89 31ss with a chevy 1500ss one weekend and it was no fun. Now my 05 harley davidson f250 pulls and stops it great. We can do 85 on the interstate and can't even tell the boat is behind you. Depends on your bake system to. Mine aren't electric they are pressure driven. All In all the Denali will do but upglrade when you can for your safety and the other drivers on the road.
FuelinAround is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
