31SS Sonic spinning IN???
Do you have a 31' SS or are you using your Donzi as a comparative subject? If you don't, take note that the X dim on the sonic, the hull degree along with configuration leads to "problems" while spinning inwards. Sure, you can get used to it but as stated, outward rotation is the easiest on this hull. Plus, specifically on my hull due to a raised X dim.
