31SS Sonic spinning IN???
I have a 31 with 525sc's spinning 4 blade 30 Bravo's. Every single Sonic I have seen has the props spinning out, yet most other boat manufacturer's spin their props IN to maximize top end speed. Has anyone tried swapping the drives on a 31 to spin in? If so, what were the results???
Go out with the props reversed and test, your shifters will be backwards but it will not harm anything, can make docking tough but not impossible.
If you like the results you can leave the props and change the cables on the controls. They are set up reverse of each other, swap the way they connect to the shifters and go.
Bravo drives are identical, the reversing is done with the controls.
My mechanic said the way the cables are set up on this boat a mere swap wouldnt work. Said it wasnt a major ordeal to swap the drives. Was just wondering if there are any gains to be made and if its worth the effort. may try running in reverse to test.
ok, back to the original question. Regardless of what needs to be done to spin the props in, WILL IT MAKE A DIFFERENCE on top end? I want to hear from someone that has done it before I try it. I just find it odd that every single 31 Ive seen all spin out. I have friends with other boats and they all spin in.
From what I understand, spinning in is most beneficial to stepped and/or staggered boats. I tried it on my 31 with 496HO's and it made no difference in top speed or in docking. However, you have a lot more power. So, give the above mentioned method a try.
the boat presently gps' anywhere between 80.7 and 82.9 depending on load and conditions. I just want to squeeze a little more out of it before I have to resort to extension boxes and smaller pulleys on the blowers, lol
