Quote:
Originally Posted by Engine Co 454
I have started my search for a used 288 MCOB. Most of the ones I have seen do not have the bow fill in cushion. Was this an option on older models? If so is it an expensive add, and what has to be done to add to a non-equipped boat?
Are there typical problem areas to look for on these boats?
It is just another cushion added in so not expensive and it lays in place. Joe at Sunsation can get one for you or if not point you in the right direction. Keep in mind the owners may have the cushion but don't post it in the ad/pictures since it isn't a big deal.
288 MCOB's debuted in 2003, 32 MCOB's came out in 04. The fairing changes in 05 from a smooth round front to a square front in the newer model. In the 288 the hull goes from a partial step in 04 to a full step in 05.
Good luck.....
