Help finding exhaust wiring 288
I am adding Corsa Quick and Quiet to my 09 288. The switch on the dash is there and lights but I have been unable to find wire in engine compartment. I have cut loose a bunch zip tied wires that go nowhere. Some are marked, some are not. I checked all with a test light but have not been able to find the correct wire. Any help would be appreciated so I don't have to add wire outside harness.
Thanks Matt
Thanks Matt
Not sure if this will help but on my Sonic the switch fed a terminal block that was mounted on the transom. Wires from solenoid Went to the block.
