JBS in Miami
and why is a race boat capable of going 200+ designed in such a way that a hull breach would allow water intrusion into the cockpit??? they should be sitting in a thick CF tub designed to prevent water and or shrapnel intrusion in even the most catastrophic failure/crash. what good is a solid strong canopy roof if the bottom of the people compartment is swiss cheese.
KiloKat
This hull was built with a different bulkhead layout than any other Mystic to save money and weight. Cosker told me last year that he would't build anymore like it again.
I think that you will see Jeff build a brand new hull and turn that one in to a poker run boat,the race version has alot more bulkheads and structure in the sponsons and that hull from what I understand was laid up as a poker run boat.It sucks however you look at it to see someones investment go down like that but when you arte racing it can happen to anyone at any time.Jeff good luck.
Registered User
The old Bacardi 46 Skater now Aqua Mania tops my list in hardcore lay up. Second would be, Drambuie, Whm, Alcone, Sloppy Joes, Jaws, Snack Attack etc. All 46 Sakters !
Here is your comment on a other post on Best Rough water Boats.
Never the less JBS Will be back!
Good Luck my fellow Turbinators!
nope unfortunatly had to be towed once in the fountain and several times up in OPA in a Pantera(03), handed them the card and got the tows all for 130.00 a year. I dont leave home without it, like Frank said, and havent had my boat under so I will give them a call and verify what would happen in that scenario
