Spark Trouble >
Spark Trouble
Spark Trouble
Old 06-12-2006, 09:00 PM
Default Spark Trouble
Anybody Know Thunderbolt Ignition Glitches? Out Checking My New 3 Blade And Ignition Today The Prop Shows Some Potential Running 50mph At 3000 Rpm But Went To Stop For A Beverage Shut The Motor Down And No Spark For A Restart! 20 Minutes Later The Spark Has Returned And Runs Ok Only To Shut Down To See If It Happens Again And Sure Enough No Spark? Could It Be The Module In The Distributer ? Msd Recommended Mounting The Coil Uprite Could Be An Issue. The Also Said When A Box Goes They Dont Come Back So Thats Out. It Must Be Running For Superfest.
z.zuperboat is offline
Old 06-13-2006, 05:08 AM
lightspeed's Avatar
Default Re: Spark Trouble
MiKe Had The Same Problem On A Customers Boat Was The Pickup In The Dist// I Have My Coil Sideways No Problem// If You Need One To Try I Got Em In Stock///
lightspeed is offline
Old 06-13-2006, 06:54 AM
Pat McPherson's Avatar
I agree with lightspeed, change the pickup first. I would also check for a crack it the coil...
Patrick
Pat McPherson is offline
Old 06-15-2006, 07:01 AM
New Coil And Install Missing Ground Wire To Bottom Of Distributor With No Effect. Still No Restart After A Shutdown, Going To Replace The Mod In The Dist Next. I Did Spot Rick In The Mako. 50 Is Fast For A Mako With A Single.
Old 06-15-2006, 11:53 AM
Hey Zup,
Check the wiring of your ignition circuit (purple wires). I had a strange problem with an ignition switch once.
I finally replaced the switch and the purple wires to and from.
When she won't restart, see if you are getting power to the coil.
Do you have a full MSD system or is it an add on to a Merc Thunderbolt? You could try without the MSD box also; I've heard guys have funky things happen with those too.
Patrick
Old 06-15-2006, 04:32 PM
sxypal2's Avatar
hey zup was that u in front of tanner yesterday at about 5. If so I was the white 21' taking a blast.
sxypal2 is offline
Old 06-16-2006, 08:22 AM
FX10's Avatar
Hey Zup,
Get the spark thingy figured out ? And are you going to make Superfesst at Robert Moses ?
FX10 is offline
Old 06-16-2006, 08:33 AM
I was out wednesday nite around 5-6. I have the new thingy for the spark installed just need to recheck the timing and hopefully im good. I would much rather make moses than claudios. We need a boatcount for either.
Old 06-16-2006, 09:14 AM
Hey Mike,
I'm going to be in Baldwin (sp) Sunday afternoon through Monday.
I may be able to escape for a couple of hours.
Please PM me your phone number.
Patrick
Old 06-18-2006, 09:22 PM
New Distributor Mod And Still No Restart After Warm. Whats The Next Guess Msd 6al Or Merc V6 Box ?
Quick Reply: Spark Trouble
