Winter upgrades: who's doing what?
#42
Wow, your bilge is super clean now!
The closing of the transom holes is A-1 !!
This is the time that a sealer should be applied to the white Gel on the bilge. That stuff holds a lot of dirt!
I wonder if it's because the white Gel is porouse?
There's gotta be a clear coating that can be applied right now whilst the bilge has not been exposed to dirt. Would make cleaning a lot easier later on!
The clear coat would be less porouse thus won't hold onto dirt too much...my $0.02
#43
Well... looked at the hull deck joint- guess what... no its not glassed together (sound familiar to anyone?) Its glassed together back behind the dash and everywhere else I can see... wtf? did they all forget about the nose back then? Seems like a pretty critical spot to be overlooked.
Hey Pat, what was going on behind the cabin liner on your boat.. ever see? Glassed, or not? How about behind the dash?
Also Noli, the bilge was only that dirty because I drained the block and winterized the engine right before getting the glass work done.. didn't bother to clean it up... usually just wipe it down with a de-greaser, or I guess you could use snow bowl if its really bad stains.
#44
I was wrong! I should have surveyed the boat before I bought it.
I was told through many deliberations here on OSO that the hull deck joint was not accessible behind the cabin liner and that is why it was not glassed together. I was also told that even if it had been glassed together I would have destroyed the boat anyway. Why up in the bow area the joint was not glassed together on my boat remains a mystery; some are, some not. I was also told that the hull deck joint should have been through bolted together as a minimum but mine only had wood screws.
I will upset many here in the Superboat forum by making this statement again, but it matters no longer.
My 1997 24’ Superboat was built with the quality normally associated with early 80s Bayliners. My 24’ Superboat was truly a piece of junk!
Now to fix your boat, I suggest the hull deck joint be glassed together where ever it is accessible and through bolted with backing plates anywhere else.
Patrick
Patrick
#46
Well, it is thru bolted... just glassing it together for my piece of mind.
Actually today while working, I realized that its impossible to access behind the cabin liner after its put together.
Not trying to bash in any way and hopefully it doesn't come off that way.... just dissapointed mainly about the back end flexing. If I didn't feel the boat was worth putting the money into, I wouldn't do it.
#48
I'm staying outta this one, but I really hope that we will still get contributions from you on the Superboat forum Rick. You've helped to awnser questions regarding my 21 in the past and I truely appreciate it.
I guess this was probably opening a can of worms and I should have delt with it like I have in the past- thru pm's.
Figured that while I was showing work that is going on to my 24 I would ask about others and then explain why I'm glassing the hull/deck joint it in the bow locker. I- so far- have not stuffed the boat.. but I figured its a possibility and decided that I want to beef it up as much as possible, so if I ever do stuff her- I won't feel like she came apart because of somthing I could have done, but didn't.
I don't know what Pat's battery tray looked like, but I'm guessing it looked like this (and actually that didn't really worry me- the screw that was starting to poke outward on the bottom of the hull did... and thats what started all of this)
#49
#50
[QUOTE=ndaniels;3289042]
You said it best. Delete the thread.
