Running Imco -1 or -2 on sutphen 31
depends on where your prop shaft is now.
Real measurements. crankshaft centerline to bottom of standard bravo drive are showing 6.3/4 inches below bottom with my -2 drives ill be 4 3/4 below my plan is to run a standard height extension box which would bring it back to the original 6 3/4. my question is should I go up more due to drive being in clean water rolling back up or is 6 3/4 a decent measurement for that hull. ive never played with drive heights much but everything is coming of the transom so this might be my chance. looking for some in put and measurements from guys that have these boats not so much theory
Thanks guys
Thanks guys
You should just set it up like my boat,shawnh's boat and letterip's.all our boats run the long input shaft and all our prop shafts are about even or just a half inch down from the bottom of the boat.
With boxes you run the drives up higher because of the water flow rising more from being set back.
