Go Back   Offshoreonly.com > Offshoreonly Marketplace > Swap Shop
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 12-21-2008, 04:25 PM   #1
1992 38SC
Need head, bare casting fine......
Have a cracked head, need a replacement (NOT CRACKED).
Casting number is 6272990
Apparently, these castings are really prone to cracks between the valve seats. I need them as close to stock as possible (not milled)
Let me know what you got, where you are at and how much you want.
Thanks,
Phil
philsnyder(at)mris.com
PJDiesel is offline   Reply With Quote
Old 12-21-2008, 06:10 PM   #2
Keeping The Lights On ...
formula 382 sr-1's Avatar
formula 1996 382 sr-1
Thanks,
Phil
I have two set off an Hp500 stock $450.00 per set plus shipping
formula 382 sr-1 is offline   Reply With Quote
Sponsored Links
Old 12-21-2008, 06:34 PM   #3
1992 38SC
These are for a MK IV block, can't use heads off of a GEN 5 (or newer).
Old 12-21-2008, 10:14 PM   #4
1990 Fountain Fever , 1988 Formula 357
Did GM make another head similar to the 990 that would work with the MK IV block ? I ran into the same problem. I have the another engine out now, so we'll see if they are also cracked. Unless you can buy them right, you're better off buying an aftermarket set. Check ebay, but make sure they were tested.
Good luck
Cold Sweat is offline   Reply With Quote
Old 12-22-2008, 07:57 AM   #5
1992 38SC
Quote:
Yes, the 3994026 is supposed to work also.
I bought one of those, it was milled down though, came out to 110cc's my machine shop is recommending against decking the 3 other heads down at this point.
Not sure what to do, buying an aftermarket set is out of the question budget wise.
Old 12-22-2008, 02:39 PM   #6
yschmidt's Avatar
'88 BULLET
I have a couple sets of stock heads that I want to get rid of. If you are still looking give me a call. 704.293.6808 - Yankey
yschmidt is offline   Reply With Quote
Old 12-22-2008, 10:19 PM   #7
1987 Chris Craft 415 Stinger
heads
I have 4 990 heads and yes they crack. I have 1 good one and 3 that could be welded. All have been maged all complete one with bad exhaust valves. Let me know a fair price if you need them
redcorvetteman3 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
sbc casting year??? Full Force General Q & A 2 04-23-2006 11:07 PM
Bravo casting defect RedDog382 Prop Talk 3 12-04-2005 12:53 PM
Engine casting numbers boatownr2 Pantera 5 08-29-2005 02:41 PM
BBC Head Casting #'s fred General Q & A 11 09-22-2003 01:29 AM
Search Engine Optimization by vBSEO 3.2.0
