new, 2-stage, K/E Extreme raw water pump.
Bought last year for a project and then only used the billet pulley. Replacement pullies are available for any application from K/E, Teague, Hardin, CP, in all colors and grooves.
Dual billet bodies, dual 1" NPT inlets and outlets, std. billet mount/brackets. Awesome, bullet-proof pumps, retail for just under $950 (Pullies are $85 - $150 depending on application.) 100% new, only out of the box twice...
Make me a good offer or it goes on E-Bay.
Thanks, Curtis @ Billet Marine
in response to PM
exactly like part # below from K/E website but this has dual water inlets and outlets. FYI, aluminum housing is hard black anodized inside and out. also has stainless steel inserts for impeller wear areas.
Dual Stage Water Pump
Part#: 625-4121-0124430
Category: Cooling Systems & Accessories
Brand Name: Hardin Marine
Description:
Dual Stage Extreme Raw Water Pump - Dual Stage Extreme Sea Water Pump
Aluminum Body, Standard Bracket, Single Groove Polished Billet Pulley (MISSING) , Common Rear Entry (DUAL SINGLE ENTRIES) , 1-1/4" NPT Inlet, (2) Single 1" NPT Outlets
The dual stage Extreme Sea Pump is the next step in our line of high performance, high volume raw water pumps. Incorporating two individual impellers this pump will double the volume of water delivered to your engine or give you the choice of separate routing to individual engine components. Dual stage pumps are commonly found on high horsepower pleasure boat applications where a dual independent water pump for an intercooler, exhaust system or oil coolers is advantageous. Available in either billet aluminum or stainless steel, this dual stage sea pump is the key to solving over heating problems.
Sale Price $1,139.99 $990.99
Description:
