| OSO Sponsor |
| OSO Sponsor |
06-26-2009, 06:16 AM
Off the Radar
Nordic 35' Flame, 22 South Bay, & GTX
Lowest Price $5,500.00
Life is getting better every day!
06-26-2009, 09:54 AM
1999 25 Outlaw
would you seperate?
06-27-2009, 06:01 AM
Off the Radar
Quote:
Originally Posted by RANDOLPH
would you seperate?
Would rather not but will thinkabout it.
06-28-2009, 12:08 AM
1997 Checkmate 283
OK, this is to all of the Merc Engine "EXPERTS" out there. I have 502 MPIs w/ 500 efi cams and stainless marine exhaust. Would the 575 stock computers work with these superchargers and my set up without reprograming (already have inconel exh valves)?
Thanks.
06-28-2009, 05:54 PM
mrtixxall
Quote:
Thanks.
He has all the wiring and computers,remove all of your stuff and install all the blower stuff and wiring..
my concern would be your camshafts,most blower cams have a lower lift and a 116 deg lode center then your compared to your 500 efi cans but you could swap them out for blower cams. another thing,blower motors need fuel pressure to live, i would suggest in up grading to a aeromotive style fuel pumps.. if you plan on turning up the boost all mercruiser engines have 2 keyways in the crank shaft and 2 slots in the harmonic ballancer to handle the xtra load so you dont spin the harmonic ballancer on the crank..
this setup requires a serpitine belt set up.
06-30-2009, 05:33 AM
Off the Radar
Thanks.
You can use these with 500 EFI cams. You will need to use the computers with the 575 SCI's & program the computers to your set up. Mark at Precision Marine can do the work for you. I talked to him about using these on my 500EFI's and still may use them. The only problem I had was it won't clear my hatch so I need to modify my hatch, which I am not found of. Let me know if you still have an intrest.
06-30-2009, 05:38 AM
Off the Radar
You will not need to upgrade the fuel with these blowers. You would only want to run 4-5 pounds of boost to keep things safe. This is not the set up to try to run 7-10 pounds of boost on a 502. You will not have to double key the crank for this blower. All suggestions you gave are good for larger applications and I would do them if I were installing a 10-71 style blower.
08-04-2009, 11:51 AM
Please Call Me On These, What Size Blowers Are On 575's? Very Interested, Call Jeff 269-998-5914
11-06-2009, 06:26 AM
Off the Radar
These are still avalible, Reduced price to $5,000 for all.
11-06-2009, 08:13 AM
Charter Member #1171
2000 36 OUTLAW SOLD SHOPPING
can you set the blower on the intake and get me a measurement from the bottom of the intake to the top of the air cleaner?
IF YOUR UNDER CONTROL,,,,,YOUR NOT GOING FAST ENOUGH !!!!
