Just removed today form a 502 MAG MPI. Fresh water only motor. I also have complete MPI fuel injection with both fuel pump and COOL fuel pump. Both came off running 2001 502 Mag MPI. $2500.00 B/O for whipple comes with charger, plug and play harness, intercooler, extra injector plate in between throttle body, hoses belt, and pulleys...everything you need and also Whipple Computer.
MPI injection will come with everything that you need to run the injection, intake manifold, upper intake throttle body, fuel rail, injectors, harness, cool fuel pump, HARDIN air filter and ECM all of it is just bolt on nothing is apart other then wheat you need to do to remove from motor. $1200.00 B/O
Package deal for whipple and MPI $3500.00.
IMCO Exhaust with risers, and all fittings, brackets BBC 454 502 540 Fresh water only also have Bolt kit for headers.
$1100.00 B/O
Also still have EMI Thunder Manifolds only BBC 454 502 540, used 1 hour!! $650.00 B/O
email me, i'll get message quicker. Everything is plus shipping or locall pick up.
ballon78@msn.com
thanks
The white stuff on bottom of whipple is white lithum grease not corrosion.
