I purchased the prop sometime in the early mid 1990's before bravo 1's where avalible. 4 blade "Custom" props were the only ones avalible at the time. I used it on a 1987 Baja Sport 240 with 750 HP 565 C.I. Blower motor. It was the only prop that would hook up, not throw pieces of blade off, good top speed and fly the hull well. I am not sure on exact dates I had maybe 50-75 hrs on it and then moved on to a different boat. It has been in the box since around 1997. As far as lab goes I was under the impression that is why it cost so much. I am not sure on the repitch. I sent it back a couple of times to gain 200-300 RPM The prop is in good condition, they painted the thru hub black and it is more dirty than any rust where the paint has come off. The rear spacer and lock washer is incorporated into the prop. All you need is a lock retainer and prop nut, standard merc stuff.
Thanks for the interest.
