Pair 454 490HP Engines Fresh
#31
Motor
Just wanted to let all know that the motor that I purchased is in and running.....seller was great to deal with and the motor is everything that he said that it was. Parts alone are worth more than he is asking.... I would buy again from him in a heartbeat! He was very helpful to my techs in breakin info, etc. Absolutely no issues....
#34
Unfortunately at less than 25 hours the motor blew...don't know what gave up...tech pulling the engine to assess the damage. Likely will need new bottom end/block, will see. Engine was no problem until then. Wondering if even though the oil pan held 13 quarts if when running hard it was getting enough oil...usually showed 60 psi or so, except when throttled down quickly from a hard run when it would drop very low. When problem occurred I had just hit a big wave and gotten a little airborne, which Donzi's should and can do, but just wondering if should do something different in the oil system for the re-do... Thoughts?
#36
