Low hour 330 HP 454 LXi $3500
I have an almost new 330 HP 454 MPI LXI, I bumped up to a 502, so I no longer need it. It has 20 hours on a new Mercury long block, and new exhaust manifolds. It looks like the 454 Mag if you want a visual reference. I purchased the boat 2 years ago with 0 hours on the replaced motor at $7000(I have all the reciepts for it too). I put 15 hours on it 2 summers ago, then last summer, I put 5 hours on it before I hit something underwater and ended my season. It does not have any accessories, as I used those on my 502. You'll need an alternator,raw water/fuel pump, Power steering, and all the pulleys. Other than that, it is complete with recently Merc reflashed computer, VST, new injectors, exhaust, and almost new Merc long block. It also has had a compression test on it, and tested good. I don't have the exact numbers in front of me, but the Marina that is doing the engine swap tested it for me. The motor is at a local Austin, TX marina, sitting on a pallet if you are local and want to go inspect it. I'm asking $3500 OBO+ the ride. Call or text me if you have any questions, or if you want to go see it. I have a few pics of it too, just shoot me a PM
P.S. This is a freshwater motor, has never seen salt.
Sean
806-789-4114
Sean
806-789-4114
