35 Cigarette Cafe No Power Updated
Im pulling my power and sticking it in something else. SO im goign to sell the boat less power and eveything else will stay with it. Check the Desc. and if you have any questions let me know. Also i know there is stuff i lfet out that i didnt think of but its all there:
1987 Cafe race redone in late 09/10. Imco full hydraulic steering. Trans have been upgraded to 9 disk and run full syn. Drives are freshend with heavy duty vertical shafts running royal purple oil and have drive showers. The paint is awlgrip base coat clear coat. All hardwar was cleaned striped and power coated. The trailer was just rebuild with dual axel disk brakes all new lights and reflectors, new bearings, seals wiring, and brake head. GPS is a Gramin 540S with the option sonar transduce already set up. Icom radio with distress wired into the GPS. Autometer gauges and Nordskeg GPS speedo with recall tattle tale. Also used a flush mount bow light.All thru hull fittings have all been replaced. Fuel pumps will stay with boat, they are 160 gph Big End Holley Black pumps withj -12 in and -10 out. Also all the indicator cables throttle and shifter cables were all replaced
3 Blade Cleave props 15 1/2x 25 come along with the boat. New sunpad was also done for the engine hatch with new louvers for the engine bay. Has 280 K planes
Can deliever just email me on it, also will consider trade of a smaller boat and cash.
There are a few pics and here are a few more if you want anythign in partuicualr please just let me know. I put 7.5 hours on the boat last season after finishing it. 1 poker run in Fall River a trip to block island and a couple runs in the river
-Mike
-Mike
Mufflers are no longer on the boat. Also Has brand new mini high torque starters and the bell housings have the coolers built in. They are stock and I do believe they are 8 plates. Couplers were also done when I did the up date. ujoints and bellows were also new
-Mike
-Mike
