502 Big Block goodies
I have 4 cams from 502's...2 cams are from Gen VI MPI motors ($75.00 each) and 2 are from Gen V carb motors ($50.00 each). I have 2 complete sets in good shape, 502 pistons and rods ($150.00 per set). I have 2 complete 502 MPI units with the wiring harnesses. One unit is ready to bolt on ($750.00) and the other unit needs alittle repair to the bottom manifold ($500.00). I have 2 stock aluminum intake manifolds with carbs from a 502 ($250.00 each). The carbs are a carbon copy of the Edelbrock 750 marine carb. Stock lifters from the 502 MPI motors ($75.00 per set), Stock rocker arms and rocker bolts (75.00 per set). Four Thunderbolt distributors...2 from 502 MPI motors ($125.00 with wires and coils) and 2 from carb 502 motors ($100.00 with wires and coils). Add the cost of the rids either on UPS or Fed-X from zip code 76179.
Were the carb motors 502 Mag motors? Any part numbers or other markings on the camshafts? Also do you have a set of the spiders and dogbone retainers that you want to sell?
What were the hours on the motors?
Thanks,
Tom
Thanks,
Tom
