Trs Drives 1 standard 1 counter rotating $3000.00
Greetings all
Jim G here , I had previously listed my scarab parts/project here, and have decided to part it, I have a pair of trs drives that were gone through by a Mercruiser mechanic,had all the u joints replaced filled with lube, then they were media blasted, acid etched, zinc primed, and then painted, they have been patiently hanging in my garage since 04 or 05 , there is one or two little chips in the paint from bumping together, they are in very good freshwater condition ,. I need 3000.00 for the pair,... they are listed on e bay right now (for pics) I would prefer pickup as shipping is going to be pricey as they are large and heavy, I could/would crate for shipping but items will be paid and cleared before any shipping and that cost will have to be paid up front too,.... I will also have 2 very nice tight clean trs transom assys,trim pumps, rams, 2 sets of small block Gil magnum exhaust manifolds 2 sets of mercury racing stainless mufflers ,2 pro built small block engines and anything else on an old scarab ( (also it will be a little while ,a 2000 1200# tri axle aluminum trailer with like 500 miles on it)) call four194three three 6983 eves aft 6 Thanks, Regards Jim
Greetings again,
I have begun disassembly this past weekend, should have the engines and transom assemblies out by the end of this coming weekend , also will have 2 original trim pumps for trs with a merc II trans ( electric shift style with the fluid reverse lockout valve on trans,if they are different,) also 2 chevy bolt pattern mercruiser II transmissions (electric shift ) complete, and a stainless trs tiebar with yokes, if any one has a need for any of these or any other parts you can think of please either pm me or phone me(phonetically spelled in prior ad,) Thanks again, Regards Jim
Scarab parting has begun Trailer for sale too
well,
engines are out , transom assys are out, exhaust is off, if any one needs small block Gil manifolds & risers , 4" stainless mufflers/ tips trs drives or transoms , Merc II trans, Merc trim pumps(looks like motors replaced) I"ve got all x2 some parts are also listed on e bay..for pics check there, Thanks, Regards Jim,. also goofed in 1st ad trailer is a 2000,tri axle aluminum, has been indoors since fall 2002(just found my paperwork) is 10,000# not 12k as previously listed probably will need tires (unless the flat spots will level out) gotta be worth 2800 419 433 6983
