New alpha / bravo trim sender diy install kit without removing drive
You can find the senders online for 70 bucks or so ....Like Tony said ....a lot of money for two bulkheads ........Looking at the back of the boat in ad ,why not just drill holes and fill with silicone....couldn't look much worse....You can buy two mini clamshells for maybe five bucks ..........................I just don't rig stuff that way ....
the deal with these are bad an idea cause the old senders and wires have a rubber plug built into the wires thats halved and is the wire stop and water inlet plug for the hole in transom assembly the wires go thru.These 2 halved plugs seal water out from coming thru the transom assembly. The 2 half rubber stop plugs as they age and degrade over time do not seal very well causing water leaks thru the transom assembly and into the bilge - It is wise to change with a new sender kit out so that the rubber halves are new and do a good job sealing water out from coming thru the transom assembly. I am telling you this cause I see it yearly first hand
DIY INSTALL IN 30 MIN WITHOUT REMOVING DRIVE !! NEW OEM Mercruiser Trim sender senders sensor kit all Alpha & Bravo 805320A0377
NO LONGER IS THERE AN EXCUSE TO OPERATE YOUR BOAT WITHOUT A FUNCTIONING TRIM GAUGE FROM THE RESULT OF FAULTY TRIM SENDER/ LIMIT SENDER .
THIS NEW MERCRUISER KIT WILL SAVE YOU HUNDREDS IN LABOR AS YOU NO LONGER NEED TO REMOVE OUTDRIVE AND HELMUT .
TO INSTALL THIS KIT YOU SIMPLY DRILL 3/8 HOLE ON TRANSOM ASSY TO RUN FULLY JACKED WIRE TO STAINLESS STEEL FEED THRU ABOVE WATER LINE .
KIT INLUDES
NEW MERCRUISER TRIM SENDER
NEW MERCRUISER LIMIT SENDER
2- STAINLESS STEEL FEED THRU TRANDOM FITTING
INSTRUCTIONS
KIT INLUDES
INSTRUCTIONS
