BBC Parts Block Crank Pistons Rods Rotating Assembly Raw water Pump HEads etc...
088 heads - running pull need cleaned up. 500.
Forged 502 crank gen vi. Machine shop says it's .030 needs polished and usable. 300
Forged 502 gen v crank std machine shop says it needs to go .010. 250
Forged 502 gen vi crank. Clean std probably needs polished. 400.
Gen v block. Hot tanked and checked 1000.
2 factory 502 intakes 30ea.
Set of 8 je std. Bore. Stock in 502 pistons w/ Gm dimple rods and arp rod bolts 450
Set of 8 8 je std. Bore stock In 502 pistons. Gm dimple rods factory rod bolts. 375.
Factory raw water/fuel pump working pull 400
Bypass crossover set 150
1 gen vi oil pan 75
502 4 bolt main caps and bolts/studs 100
Mellings hv bbc oil pump 50
502 water pump with 3 rib pulley 50
Factory manifolds and risers mk offer
2 sets factory valve covers for 502. 30 ea
All in st. Louis area. Consider trades for electric fuel systems, raw water pump without fuel pump. Dizzy and coil.
1 gen vi oil pan 75
