Cutting Edge 22P 5 blade
I own the first two 5 blades bravo's they every made. Still using both props today. One that I damaged and they repaired has taken a beating over past five seasons as my "trash prop" used in shady water conditions. Runs within 1mph of the other, just higher revs.
You should see excellent out of the hole thru mid-range performance with probably a bit higher slip numbers on the top end because of the 5 blades drag.
If that was a 26P I'd be all over it.. I'm looking for a wake boarding prop, 10 less than my smokin 37P.
