CMI Tails with Silent Choice/Y-Pipes & Actuator
These are CMI Tails for Bravo application. These are the muffler clamp style, not the "rope" style.
2 sets. Have the Y-pipe, actuator, tubes, etc.....
The actuator (like so many of them) will only hold for about :45 seconds before it starts fading back to thru-hull.
Would like to sell it all as a set.
In decent shape. Could probably use a thorough polishing and does have some light surface scratches. I have a couple extra bushings as well that go in the turndown rod.
1500 + shipping for everything.
Just bringing this back to the top since I've got them in the back seat of the truck. 1,400 for everything shipped.
I will separate the tails / YPIPE / Actuator if anyone wants just certain pieces but would prefer to sell the tails in pairs.
Back to the top. Getting anxious to order some straight tails and took the Transom Assemblies off yesterday so I have everything in the garage.
Any takers at 1200 for both pairs?
Would consider separating at this stage.....
I'm interested in this but don't know enough about it... I have CMI headers with 4.5" tips, I believe they are dry to the transom. Any idea if these would work and how they would be installed?
ryan
ryan
What is the Inside Diameter of your header where it would meet the tail? I believe these are only 4 inch ID where the tail meets. I can measure it when I get home.
What else do you need to know about them? How the Y-Pipe setup works? These are set up as a wet setup. The water flows around the header, up to the top of the header then there is a little jumper tube over to the tail - the water then dumps out into the exhaust at the end of the tail.
Here is the CMI dimensions from the website. I have the standard E-Top headers http://www.custommarine.com/tailpipes/index.php
You can email me if it is easier - eric.ancarrow ( at) ferguson.com
